1996 Toyota 4Runner Brake pedal fading
1996 TOYOTA 4RUNNER
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
SVEEDE
I have a 1996 Toyota 4runner limited with brake problems. When depressing brake pedal to point of strong resistance & then continuing pressing the pedal down, the pedal will gradually move towards the firewall/floor to be almost tight against the firewall/floor usually within a matter of 1 minute. Brake system has been bled 5 different times including a total gravity bleed at each wheel. Master cylinder has been replaced. With pedal held down as far as it will go, transmission in Fwd or Rev & depressing gas pedal, vehicle will not move, forward or in reverse. I have tried panic stops & numerous gradual stops & vehicle will stop as it''s supposed to. However, when @ a stop sign or signal, it doesn't provide any confidence for me in this condition. This happens with engine running or off. Any suggestions?? help!!!
Apr 27, 2008 at 7:17 PM
If the brake lines/caliper/wheel cylinders are not leaking-replace the brake master cylinder.
Apr 27, 2008 at 7:33 PM
