1995 Toyota 4Runner Hooked up jumper cables backwards
1995 TOYOTA 4RUNNER
14,000 MILES • 6 CYL • 4WD • AUTOMATIC
HELLFIRE54Z
So I had a momentary lapse of common sense and hooked my jumper cables up backwards (I've jump started cars dozens of times I was just in a rush) by the time I noticed it I went to pull the cables off and sparks flew and the battery was toast (almost melted the positive post) so I replaced the battery and nothing, no lights no power at all. upon some inspecting I found the main 80a fuselink was fried along with a couple 15a fuses. so I replaced those and now I have power but the car won't start, I turn the key and nothing happens. I really can't afford to bring it to the shop. Anyone have this happen to them before. I think it's either the starter motor or the ECM computer. Any help would be really awesome!!
Also how can I test the ECM to see if that's the problem Cuz they're expensive and I really don't want to replace it if that's not the issue
Dec 6, 2009 at 11:05 PM
MHPAUTOS
  • 31,937 POSTS
Hi three,
You will first need to run a diatonic scan to see if this shows up any further problems, the testing of the ECU is a specialist electronics job, i feel that you may have fried the ECU, do the scan first to see what that shows, if it wont scan then i would be fairly sure the ECU is destroyed, start here.
Mark (mhpautos)
Dec 6, 2009 at 11:14 PM
