1995 Toyota 4Runner
1995 TOYOTA 4RUNNER
19,000 MILES • 6 CYL • 2WD • MANUAL
WENDY47
  • 4 POSTS
the engine sound likes its working overtime and I don't get there very fast also eating a lot of gas. when I put the gas peddle to the floor for exceleration I don't when going up a hill I loose speed also chuggs at lights
Dec 8, 2009 at 2:00 PM
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 8, 2009 at 2:25 PM
