1994 Toyota 4Runner Timing belt install
1994 TOYOTA 4RUNNER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
RUUDBOY1
What is the correct sequence for replacing the timing belt. Old belt is off. Concerned with correct cam to crank to cam timing and belt tensioning. I have located the timing marks on cam and crank sprockets. Do I simply align all marks and install belt?
Oct 18, 2008 at 8:02 PM
Put the engine no.1 piston on its compression stroke/TDC make sure its not on exhaust stroke-otherwise its gonna be 180deg off Line everything up as you see below then slap the T-belt on.
https://www.2carpros.com/forum/automotive_pictures/12900_timing_belt_7.jpg
Oct 18, 2008 at 8:14 PM
