1994 Toyota 4Runner leaking red fluid
1994 TOYOTA 4RUNNER
184,000 MILES • 6 CYL • 4WD • MANUAL
ADROCK77
Recently had my whole clutch hydraulic system replaced as there was no pressure and the clutch was sinking to the floor. Everything has been fine for 2 weeks and I noticed this morning what appears to be antifreeze/coolant leaking from the front bottom left part of the engine. I assume it's antifreeze as it's a thin red liquid. There was a puddle on the ground this morning. The truck has been idling very low since the clutch replacement and sometimes stalls. Is this a transmission fluid leak and therefore I should not be driving and getting a tow back to the mechanic.
Sep 14, 2009 at 12:45 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Can you tell me if it is oil or water? check the coolant is the type used in your car red?
Mark (mhpautos)
Sep 14, 2009 at 5:28 PM
