1994 Toyota 4Runner Back window wiring issue
1994 TOYOTA 4RUNNER
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BETSY2008
I am unable to roll down my back window on my 1994 4Runner. It is not the motor or the switch, but a wire that is damaged. I had a friend check this out. The problem is I need to know how to access this part to fix the wire.
Thank you,
Dec 7, 2008 at 1:12 AM
DAVE H
  • 13,384 POSTS
REMOVAL & INSTALLATION
POWER WINDOW MOTOR
Remove door trim panel and waterproof shield. Remove glass retaining bolts and glass. Remove window regulator nuts and remove window regulator. Remove power window motor retaining screws and remove motor from window regulator. To install, reverse removal procedure.
POWER WINDOW SWITCH
Disconnect negative battery cable. Pry out power window switch from door panel using flat screwdriver. Disconnect power window switch connectors and remove switch. To install, reverse removal procedure.
Dec 8, 2008 at 9:31 PM
