My air conditioning works fine when you start the truck and works for about 5 minutes. Then the AC quites working and does not work for the rest of the day although the compressor still cuts on. This is always the case when it is over 80 degrees outside. When it is below 70 degrees, AC will work all day. I checked the freon level and it is fine. Could not find any expansion valve. Got no leaks. Could it be evaporator.. I'm stumped.
Aug 5, 2009 at 9:20 AM
