I have a 1993 4 runner with about 100,000 miles on a v-6. 4 wheel drive automatic. About 2 years ago the engine started missing and running real bad. I had the heads planed because I seen a small water leak between the head and block. Put it back together and it still ran bad. Took it to the local dealer and they wanted $400 to fix a couple minor things before they would put it on diagonistic machine. (Not gonna happen) sent it to another mechanic and he found a bad valve, so off with the heads again and back to machine shop. After 6 new valves and 2 new cams new plugs wires dis. cap and everything it now idles fine but has no power to drive. I don't think the advance is working but is there a sensor that would cause that or part of the computer? Please help it has been off the road for 2 years now and have stuck a lot of money in it and really need to get this fixed.
Jul 26, 2007 at 9:39 PM
