1992 Toyota 4Runner The engine fails when running
1992 TOYOTA 4RUNNER
120,358 MILES • 6 CYL • 4WD • AUTOMATIC
LUIS ALFREDO
When the engine is cold, sometimes the engine fails running, the revolutions go down an up, seems no electricity or gasoline in system, sometimes the engines goes off, and i have to turn on again. That doesn't happen when the engine is hot running on the highway. I all ready change the air and gasoline filter, the sparks and cables and check the timing, but the problem continues.
Nov 21, 2008 at 5:55 PM
Check the fuel pressure and the coolant temperature sensor and idle air control valve.
Nov 21, 2008 at 6:18 PM
