1991 Toyota 4Runner transmission
1991 TOYOTA 4RUNNER
237,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAE26
i recently bought a 1991 4 Runner for a couple of hundred dollars. i knew it needed work but i could not pass up the deal. my engine purrs like a cat, but when i engage the gear selector lever from park to any other gear, the vehicle feels as if the transmission engaged but it does not move either forward or back. i changed the transmission fluid and filter already. i ask if you guys can assist me with this issue. i have the money to drop on a mechanic, but i would like the experience of fixing this vehicle myself.
Mar 3, 2010 at 10:00 AM
KHLOW2008
  • 41,814 POSTS
Hi jae26,
Thank you for the donation.
It could be a faulty transmission which requires rebuilding or replacement, a faulty drive train or transfer case.
Let us start by checking the drive trains. With gear in park on a level ground, release the handbrake and try to push the vehicle forward or back wards.
If vehicle does not move, the drive train is ok.
Mar 3, 2010 at 12:05 PM
