1991 Toyota 4 Runner, 4WD, 197,000 miles, 3.0 litre engine.
My turn signals quit working. When they quit I heard a sound like arcing coming from under the steering column then it quit. I was told by a certified mechanic that the turn signal flasher is bad so I bought a new one. The problem is I can not find the location of the turn signal flasher to replace it. I found the Emergency flasher and by the way the Emergency flashers work fine. I even swapped out the new flasher I bought with the old emergency flasher just in case they use the same flasher and had the same results. I was told there should be a seperate flasher for the turn signals and it should be located near the emergency flasher under the dash by the steering column or on or near the fuse block. I have disassembled the entire dash under the steering column and the left kick panel where the fuse block is and have not been able to locate it. There are 3 round relays on the fuse block but I don't know what they are for. The flasher I have is square. Please help!!!!!
Thank you.
Homer87
[email protected]
Thank you.
Homer87
[email protected]
Jul 22, 2007 at 3:50 PM
