Engine Performance problem
1990 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
I am attempting to put the vacuum lines back in the correct order but have a question as to the routing of the vacuum lines coming off the vacuum valve on the bottom of the power steering pump. There is also a vacuum valve on the right wheel house that has an adjustment screw and two large vacuum lines that I am unsure of where to plumb them. I have found routing diagrams for the other lines for the EGR, throttle body, air suction and fuel presure regulator but can find nothing on the other components I have outlined. Any help would be appreciated.
May 24, 2010 at 10:54 PM
