1989 Toyota 4Runner FUEL PUMP NO POWER
1989 TOYOTA 4RUNNER
TIMHAZELBAKER
Engine Mechanical problem
1989 Toyota 4Runner 6 cyl Four Wheel Drive Manual
I HAVE NEW FUEL PUMP NEW RELAY STILL NO POWER TO PUMP DONT KNOW WHAT THE PROBLEM IS???? CAR WONT START NO GAS IS BEING PUMPED MY FUSE HAS POWER MY RELAY HAS POWER MY PUMP NO POWER
Feb 19, 2010 at 6:50 PM
In the check connector jumper Batt to Fp did the fuel pump come on?
Block the air vane/flap wide open in the airflow meter and attempt to start-did it fire up?
Feb 19, 2010 at 6:57 PM
Check the EFI fuse if okay-test the circuit opening relay-
Remove the jumper in the DLC and block open the flap in the airflow meter did the fuel pump come on?
Feb 19, 2010 at 7:07 PM
