1989 Toyota 4Runner fuel injection
1989 TOYOTA 4RUNNER
BEACHCOMBER4YOU
  • 23 POSTS
Engine Mechanical problem
1989 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 169 th miles
This engine ran before I changed bad head gaskets and install new fuel injectors. Problem is Engine will not start. The injector resistance tests ok 13.7 Ohms
Tested injector circuit with NOID TEST LIGHT - Test ok. Can hear injectors clicking while engine is being turned over. Engine will fire , I believe off of cold start injector and then die. At this point I'm out of ideas. Any help will be greatly Appreciated.
M. Genzano
May 22, 2010 at 6:55 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, have you check fuel pressure at the rail? are there any set fault codes coming up in the ECU?
mark (mhpautos)
May 22, 2010 at 9:09 PM
BEACHCOMBER4YOU
  • 23 POSTS
I have no tester to check for fault codes. What kind of tester will I need? What will codes tell me?
May 22, 2010 at 10:44 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need an OBD 11 scanner with a Toyota interface, the ecu will hold set fault codes for any system that it controls, if one or more of these systems are out of parameter or not sending reference signals, you will get a dedicated fault code for that system.
mark (mhpautos)
May 22, 2010 at 11:40 PM
BEACHCOMBER4YOU
  • 23 POSTS
Good Morning,
First of all , Thank you for all you help . Can this test be done without the engine running?
M.Genzano
May 23, 2010 at 9:02 AM
MHPAUTOS
  • 31,937 POSTS
Yes, you just need the ignition on.
mark
May 23, 2010 at 9:35 PM
BEACHCOMBER4YOU
  • 23 POSTS
Hello mhpautos, !989 Toyota will still not keep running. Engine will start right up and the die. I have checked all that I will list for you. 1-fule pressure = 40PSI 2-injector resistance = 13.7 Ohms 3-Node light test = goog 4- can hear injectors clicking while enging is being cranked over 5-No codes come up on Ck. Engine light With all this being tested it still wont stay running. Any suggestions would be greatly appreciated. GOG BLESS YOU AND FAMILY IN JESUS NAME A=MEN!! M.Genzano
https://www.2carpros.com/forum/automotive_pictures/530367_Master_Mechanic_2.jpg
May 27, 2010 at 3:03 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, OK next is to check that the spark is good and hot and clean the plugs as if the engine is not firing and the fuel system is OK as it seams it is, the plugs will be rather fuel fouled by now and that will also be a problem, let me know what the plugs look like.
Mark (mhpautos)
May 27, 2010 at 6:30 PM
BEACHCOMBER4YOU
  • 23 POSTS
Hello mhpautos, I checked spark and it is strong. Spark plugs were damp. I had installed all new plugs from the begining. I found out something while experimenting, If I put a jumped across +B - Fp ,and pump the gas peddle after engine fires as it has in the past ,I can keep the engine running for a longer period of time, but still wont stay running. HAVE A GREAT WEEK END AND GOD BLESS IN JESUS NAME A=MEN!!! M.Genzano
https://www.2carpros.com/forum/automotive_pictures/530367_Master_Mechanic_3.jpg
May 28, 2010 at 4:05 PM
