Engine is a new long block with 16k - I have a stumble/miss or hesitation at cruising throttle position. Is somewhat noticeable during acceoeration but is much more prevalent when throttle is part-way. I have replaced & properly adjusted TPS sensor, had fuel injectors rebuilt with all new seals, fixed exhaust leaks and it runs much better but can't get rid of this stumble. Does not matter if engine is cold or up to temp.
Once throttle gets to a certian spot it starts to hesitate and gets worse as throttle is pressed a bit further, then will accelerate if continued to press throttle down - then as throttle is lifted there is a point where the condition stops and runs better...so if you press down the throttle around this point it actually hesitates more - let off and the acceleration increases. Any thoughts?
Apr 14, 2008 at 10:02 PM
