Touch up paint
2010 FORD FOCUS
10,160 MILES
INMYHEART28
  • 223 POSTS
I had touch up paint applied to an area that needed it. Is that fairly permenant? Will it wear off in time? If so in how much time? Or is the touch up paint similar to all other paint in that it will stay on?
May 30, 2013 at 7:36 AM
INMYHEART28
  • 223 POSTS
PS it was real car paint that was used. Not a lesser quality.
May 30, 2013 at 7:38 AM
CARADIODOC
  • 34,306 POSTS
I never heard of a paint that was not permanent. As with any paint of any quality, it adheres based on the surface prep. None will stick to oil, wax, or products containing silicone. Regular car paint is applied over layers of sealers and primers. That's what body shops do to produce superior results. Touch up paint in little bottles are designed to work on small areas without needing separate primer applied first.
May 30, 2013 at 9:04 AM
