Total loss of all electrical while driving
1994 GMC SIERRA
190,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JEFF THOMAS2
  • 7 POSTS
I was driving and my truck died. I now have no power to anything, not even the headlights or dome or ignition. I found a ground wire from the cab to the frame broken. I replaced it and checked my fuses in the cab by the drivers leg area. I have power from the battery to the starter. I need help please. Did the ground strap cause another failure somewhere? I see no fuseable links? Auto two wheel drive. Thank you! Jeff
Oct 27, 2016 at 8:14 PM
HMAC300
  • 48,601 POSTS
there are fusible links on both sides of block at junction block rear of engine compartment. also, check breaker see picture.
Oct 28, 2016 at 7:25 AM
JEFF THOMAS2
  • 7 POSTS
Thank you, I will look.
Oct 28, 2016 at 7:27 AM
JEFF THOMAS2
  • 7 POSTS
Where are the breakers located? please
Oct 28, 2016 at 9:36 AM
JEFF THOMAS2
  • 7 POSTS
There is an auxiliary breaker on the passenger side firewall, could that be it? I have juice from the battery to the starter. I have wrenched for many years so I am not completely illiterate. I do not have power for the headlights when the ignition is off and was wondering if all this has to go through the ignition switch as well? This is a stumper! Lol
Oct 28, 2016 at 9:40 AM
JEFF THOMAS2
  • 7 POSTS
Is the junction box with the fuse-able links on the passenger side firewall? I see the wires go to a bar shaped post there but I do not see the fuse-able links there?
Oct 28, 2016 at 9:43 AM
HMAC300
  • 48,601 POSTS
the fusible links are wire and when you see the picture I sent it says black going to a red wire you have to use the same gauge for it. headlights can run through ignition switch but if the link is burnt no power. it states in reply right hand side of truck which is always passenger side.
Oct 28, 2016 at 12:04 PM
JEFF THOMAS2
  • 7 POSTS
Okay. Thanks again. Brother, I will get back to you tomorrow. Have a great day.
Oct 28, 2016 at 12:23 PM
JEFF THOMAS2
  • 7 POSTS
Hey brother . Thank you very much! I found the fuseable link and that was it ! I'm rolling again . JT
Oct 29, 2016 at 1:17 PM
Nice work brother, we are here to help, please use 2CarPros anytime.
Best, Ken
Nov 1, 2016 at 9:52 AM
