Total electrical power loss
2005 MERCEDES BENZ ML350
225,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
MGUETHLING
While driving, my car loses all electrical power for a split second, not long enough for me to need to restart it. It seams to triggered when I hit the brakes, turn on the radio, anything that takes a bit more power. It will go days working fine and then act up 2 times in 15 minuets. No codes, starts and runs grate otherwise.
Sep 11, 2021 at 7:31 AM
SQM
  • 6,383 POSTS
Unless you already have check the battery cable. Make sure it is secured and does not have any corrosion.
It is strange for it to loose all power but not stall the engine. That means the engine ignition system stays operational.
When this happens do you loose the radio? how about the dash gauges?
Let me know a little bit more information.
Thank you.
Sep 11, 2021 at 7:22 PM
