I am doing an LM7 swap in my vehicle listed above. I have been following your LM7 video series. I am about to start installing pushrods and rockers. According to your video, you show tightening the rocker bolt 1/4-3/4 turn, then about a half turn, and finally torquing to 22ft lbs. I am inquiring if there is a particular amount of time to wait prior to each step to allow the spring tension to push any lifter oil out? Also do I need to follow firing order or just feel pushrods as I rotate engine assembly for both to come off cam lobe? I appreciate your time and videos.
Feb 28, 2023 at 12:22 PM
