What are all the torque specs in ft lbs. for these reinstalled parts?
And which ones need the blue Loctite or any thread sealer or Teflon, etc?
Timing chain tensioner.
Timing chain sprocket bolt atop.
Timing cover bolts in middle.
2 End of oil pan bolts going into timing cover.
Water pump bolts [also note i saw white stuff on 1 bolt in the middle of bolt].
Big dampener/balancer bolt [any sealer?].
Top single pulley bolt [small one].
That little plug on left side of timing cover [saw white stuff on old threads].
And any other important ones, though I have covered most.
And since the mating surfaces on both timing chain cover and side the gasket goes against can be uneven can i put a thin layer of black RTV on both sides of the rubberized U-shaped gasket as I'm installing it? I don't want a repeat leak.
And is the water pump gasket, [blue or paper like] to remain fully dry on all sides?
Apr 10, 2022 at 7:33 AM
