Torque Specs
2013 CHEVROLET AVEO
20,000 MILES • 1.8L • 4 CYL • AUTOMATIC
MSBRIDGES
  • 11 POSTS
My husband is needing the torque specifications on the head bolts & camshaft carrier bolts for a 2013 Chevy Sonic LT 1.8L engine. Can you please help?
Jan 19, 2016 at 1:57 PM
This is straight from the repair manual. (DIAGRAMS BELOW)
Head Torque specs
Tighten the bolts (1) in 5 passes. Use the EN-45059 sensor kit :
First pass to 25 N.m (18 lb ft).
Second pass to 90°.
Third pass to 90°.
Fourth pass to 90°.
Final pass to 45°.
Camshaft Caps
Install the camshaft bearing caps in sequence (2, 3, 1, 4) Tighten the camshaft bearing cap bolts to 8 N.m (71 lb in).
May 26, 2017 at 10:35 PM
BRANDO PULEY
  • 8 POSTS
Hallo Ken, can you please assist me with the torque specs on the camshaft gear bolts on a 2013 Chevy Sonic 1.6LS/1.8L?
Nov 17, 2017 at 10:06 PM
Sure no problem can you please start a new post so we can get the car right :)
Please post your question here
Nov 18, 2017 at 2:39 PM
BRANDO PULEY
  • 8 POSTS
I already did and was assisted, thank you for your response.
Nov 18, 2017 at 2:44 PM
Sweet! Have a good weekend :)
Nov 18, 2017 at 2:54 PM
BRANDO PULEY
  • 8 POSTS
Thanx, the same your side.
Nov 18, 2017 at 2:59 PM
