Hello. (The car listed above has a Turbo)
1. I have a leak at the Turbo Oil Line, Part#25198546v, that I would like to replace but don't know if it needs to be torqued and the specs. (E10 and T45)
Also, should the oil line be filled with oil, same oil when replacing?
2. I will be replacing the spark plugs with the same type and wanted to know the torque specs.
Also, conflicting views on whether there should be a grease like added to the thread or top of plug, different types for each of course, vs. not doing anything at all.
Let me know if you have any questions.
Thank you for your time.
May 1, 2022 at 7:23 AM
