Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Avalon
Engine
Oil Filter
What the Torque specs for Oil Drain Bolt and Oil Filter?
1995 TOYOTA AVALON
200,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
AVALON1995
MEMBER
FOLLOW
Torque spec for the oil drain bolt and the oil filter needed.
Cheers!
Thank you!
Oct 14, 2021 at 10:53 PM
CERTIFIED EXPERT
Good morning,
I attached the torque spec for the drain plug below. I also attached the torque specs for the engine itself for you to view.
Drain Plug To No. 2 Oil Pan
33 ft.lb
As far as the oil filter, the spec is hand tight plus 1/2 turn.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Let me know if you have any other questions.
Oct 15, 2021 at 2:27 AM
