Sure, here you go.
Cylinder Head Bolts .................... 76-81 Nm (56-60 ft lbs)
Valve clearance
IN .................... 0.18 - 0.24 mm (0.0071 - 0.0094 inch) (0.21 ± 0.03 mm (0.0083 ± 0.0011 inch))
EX .................... 0.28 - 0.34 mm (0.0111 - 0.0133 inch) (0.31 ± 0.03 mm (0.0122 ± 0.0012 inch))
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
May 13, 2023 at 11:35 AM
