I'm putting the flywheel back on just got it resurfaced, need the torque specs for the six bolts flywheel. And pretty much the rest I'm putting back on the pressure plate the clutch, slave cylinder, the transmission bolts and even though I didn't need to, but I took off bolts that were on the driver side of the transmission looks like a figure eight cover. And the tie rods and sway bar, the nut that goes on the drive axel when I get the front drive axels put back in the wheel hub. I believe the lug nuts are 90. Oh, and the subframe torque specs and the motor mounts front driver and rear mounts. My first time replacing the clutch.
Nov 17, 2021 at 1:15 PM
