Torque settings install of exhaust manifold needed?
2010 HOLDEN CRUZE
146,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TAINA
MEMBER
FOLLOW
Need torque settings and sequence of tighten nuts for install of exhaust manifold and oil cooler part.
Sep 15, 2024 at 2:47 PM
CERTIFIED EXPERT
Sure, here are the instructions and the torque specs on how to replace and tighten the exhaust manifold. Be sure to clean the gasket surface thoroughly and I would use a little RTV to help seal the gasket. Check out the images (below). Let us know if you need anything else.
