Good morning.
The specs are below for your rod bearings Let me know if you need any other specs.
Tightening Specifications
Connecting Rod Cap Bolts .................... 27 Nm (20 ft. lbs.) PLUS 90 degree turn
Dimensional Specifications
Bearing Clearance .................... 0.010 - 0.048 mm (0.0004 - 0.0019 in.)
Side Clearance .................... 0.10 - 0.35 mm (0.004 - 0.0138 in.)
Piston Pin Clearance .................... 0.015 - 0.028 mm (0.0006 - 0.0011 in.)
Bearing Bore Out of Round .................... 0.004 mm (0.0002 in.)
Total Weight (Less Bearing) .................... 612 grams (21.588 ounces)
Cheers, Roy
Aug 25, 2018 at 7:35 AM
