I have done much research into the issue, but would like to get some input as my symptoms are similar, but not the same as others I have read thusfar. I own the car listed above with the 42rle transmission. I have owned the car for about two months and have only had to replace the typical worn out suspension parts due to clunking. The recent issue that has just shown up over the last week or so is a shudder when the car is around forty mph. It happens everyday almost like clockwork. I will try to be as detailed as possible. The first startup of the day I leave my house and drive roughly two to three miles at which time I stop at the local convenience store at which time I shut the car off. A few minutes later I leave the store and get around a mile or two down the road when the shuddering begins. Like I said it is always around forty mph. The shudder lasts only a minute or two then eventually stops and does not return until the same time the following day. At first it was intermittent but does seem to be getting worse as today it began shuddering within a mile of my home between twenty five and thirty mph cruising through my neighborhood which cleared before I got to the store, but shuddered again in within a mile of leaving the store this time which again cleared a few minutes later and did not return for the remainder of the thirty mile drive. When leaving work on the reverse path home the car operates perfectly without issue everyday. I did try adding 4oz of Mopar LSD friction modifier that I read was recommended in other posts, and seemed to work for about a day although there was a shudder just much milder but reverted to the original condition the following day and has remained. Should I try adding more friction modifier? What should my next step be?
I forgot to mention I did check the transmission fluid level and it was correct and pink in color.
Will a TCM reprogram fix this? It seems that it runs fine until the EMCC is active. This is when it appears to have the shuddering issue. This is the link I found during my research that makes me think the EMCC is causing the issue: 42RLE poor performance.
Apr 29, 2018 at 5:26 PM
