it may not be torque converter clutch solenoid causing problem. check engine light would be on as well.
Aug 15, 2016 at 7:14 AM
DANNY TANNER
MEMBER
Got code 13 says no crank angle. But I replaced distributor and timing belt. All OME parts.
Aug 15, 2016 at 8:45 AM
HMAC300
CERTIFIED EXPERT
check for a cracked distributor or rotor cap and connections at ECM then follow checks on chart. that code means there is no rpm signal so it may be a bad ECM.
Image (Click to enlarge)
Aug 15, 2016 at 9:33 AM
DANNY TANNER
MEMBER
Okay, l will do that, and get back to you! Thanks for all the information. Man, I am glad fellows like all of you are willing to help guys like me! I will be in touch. Thanks again!
Aug 15, 2016 at 11:28 AM
CERTIFIED EXPERT
No Problem!, we are here to help, please use 2CarPros anytime
