Where is the Torque Converter Clutch located?
2003 JAGUAR S-TYPE
47,000 MILES • 3.0L • 2WD • AUTOMATIC
AUSTINO
  • 220 POSTS
Good day,
Do you know where the torque converter clutch solenoid is located?
What does it mean by circuit performance or stuck off?
Thank you.
Jul 30, 2024 at 10:11 AM
It means the torque converter clutch solenoid is not responding, most of the time to will be the torque converter clutch solenoid itself. Here is the location so you can swap it out and then clear the codes when completed. It does not say which one it is so you will need to test them all or get a rebuilt valve body. Here is the location of the shift and converter lock up solenoids. Use a voltmeter to check the coil resistance which all of them should be about the same.
This guide can help:
Jul 30, 2024 at 12:54 PM
AUSTINO
  • 220 POSTS
Thank you so much.
Jul 30, 2024 at 2:03 PM
You are welcome, please use 2CarPros anytime we are here to help.
Jul 30, 2024 at 3:32 PM
