In total it holds about 8 quarts of fluid for that car. Some hold far more. The reason to check it while it is running is so that you get a reading of the level while it is in use and most of the fluid is in the working parts of the transmission. If you check it with it shut off it will read high because all of the fluid in the passages, converter and systems drains back into the pan. If you filled it cold as soon as you start it and the pump pulls in the fluid it's very possible that it would not have enough fluid. In a transmission the fluid does a lot, it gets pressurized to operate the parts but it also lubricates the bearings and bushings and it also acts as a coolant.
Start it and run it through the gears, now with it idling check the level. Pull the stick, wipe it off and put it back. Check it. if it's to high remove some (being new fluid you could use an extractor that is clean and save the fluid).
May 13, 2025 at 11:48 AM
