Engine torque specs needed and does this engine use normal or flex bolts?
1995 FORD F-150
212,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
BOBBYB69
  • 37 POSTS
Hello, just needed to know if the truck listed above uses normal or flex bolts? My heads are cast iron?
Apr 20, 2023 at 1:21 PM
BOBBYB69
  • 37 POSTS
Shoot I forgot to ask for all engine torque specs, please
Apr 20, 2023 at 1:22 PM
Here are the torque specs for the engine and I have included how to use a torque wrench video in case you need it. There are two different kinds of bolts the torque to yield bolts will need to be replaced, see below:
https://youtu.be/juOClONIWeY
On engines with non-flanged hex head bolts, using sequence shown in Fig. 18, torque cylinder head bolts in two steps; first to 55-65 ft lb, then to 65-72 ft lb.
On engines with flanged hex head bolts (torque to yield), using sequence shown in Fig. 18, torque cylinder head bolts in three steps; first to 25-35 ft lb, second to 45-55 ft lb, then tighten an additional 1/4 turn (85-95 degrees).
A/C Compressor To Bracket .................... 18-22 ft lb
Alternator .................... 30-40 ft lb
Alternator Pivot Bolt .................... 40-50 ft lb
Camshaft Sprocket Retaining Bolt .................... 40-45 ft lb
Camshaft Thrust Plate .................... 9-12 ft lb
Clutch Housing Or Transmission To Engine .................... 40-50 ft lb
Connecting Rod Cap .................... 19-24 ft lb
Crankshaft Damper .................... 70-90 ft lb
Cylinder Head .................... [01]
Distributor .................... 17-25 ft lb
Exhaust Manifold .................... 18-24 ft lb
Fan Shroud Bolts .................... 5-6 ft lb
Flywheel To Crankshaft .................... 75-85 ft lb
Front Cover .................... 12-18 ft lb
Intake Manifold .................... 23-25 ft lb
Intake Manifold Pipe Fittings .................... 12-18 ft lb
Intake Manifold Vacuum Fittings .................... 6-10 ft lb
Main Bearing Cap .................... 60-70 ft lb
Oil Inlet Tube To Main Bearing Cap .................... 22-32 ft lb
Oil Inlet Tube To Pump .................... 10-15 ft lb
Oil Pan Bolts .................... 9-11 ft lb
Oil Pump Retaining Bolts .................... 22-32 ft lb
Power Steering Pump To Bracket .................... 30-40 ft lb
Pulley To Damper .................... 40-50 ft lb
Radiator Support To Frame Insulator Bolts .................... 30-35 ft lb
Rocker Cover .................... 10-13 ft lb
Rocker Arm Fulcrum Bolt .................... 18-24 ft lb
Spark Plug .................... 10-15 ft lb
Thermactor Pump .................... 30-40 ft lb
Thermactor Pump Bracket To Block .................... 30-45 ft lb
Thermactor Pump Bracket To Head (3/8-16 Bolt) .................... 30-40 ft lb
Thermactor Pump Bracket To Head (7/16-14 Bolt) .................... 40-50 ft lb
Thermactor Pump Pivot Bolt .................... 30-40 ft lb
Upper To Lower Intake Manifold .................... 12-18 ft lb
Water Outlet Housing .................... 9-12 ft lb
Water Pump Retaining Bolts .................... 12-18 ft lb
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Apr 21, 2023 at 12:26 PM
BOBBYB69
  • 37 POSTS
Okay, I decided to completely pull the engine. When I dropped the oil pan, I found the tip of number 4 Piston in it. Is it fixable?
Many Thanks as always y'all are the best.
Apr 21, 2023 at 3:32 PM
If the piston is broken it will need to be replaced, do you mean the skirt of the piston? Can you upload an image?
Apr 22, 2023 at 10:31 AM
BOBBYB69
  • 37 POSTS
If I'm doing this twice, I apologize. It is the skirt. Skirt tip I'm calling it. Now that I've researched it the sound, I'm getting is a piston slap or slapping metal sound.
Would y'all be able to recommend either a used or rebuilt engine place? Just looking for an opinion. I've had two places trying to scam me by false information and wanting me to wire payment. Got three others showing the same engine for sale.
Many Thanks, BobbyB
Apr 22, 2023 at 3:00 PM
BOBBYB69
  • 37 POSTS
I've misplaced the piece. Sorry
Apr 22, 2023 at 3:01 PM
No problem, either way the engine will need to be replaced or disassembled and repaired. I like the rebuilt engine from Ford, they have a great warranty and any ford dealer will take care of the engine if you should have a problem.
Apr 24, 2023 at 11:16 AM
BOBBYB69
  • 37 POSTS
Can you replace one piston? When all this started, I thought of the lifters. After cleaning the top end, I went on a test drive and my head gasket blew on number two cylinder and forced the compression into my cooling system blowing a hole in the upper hose connection. Literally blew a hole in the plastic. Also had coolant in number two cylinder. The lower intake had a really slow leak before this. I am wondering if it sealed it properly after re-gasketing top end is why Head gasket blew? That's when I took it out and found the piston skirt broken.
As Always, Many thanks, BobbyB
May 2, 2023 at 1:33 PM
Yes, you can replace one piston, but the cylinder will use oil unless you have the block re-machined and use an oversized piston.
May 3, 2023 at 11:26 AM
BOBBYB69
  • 37 POSTS
Okay, thanks my friends.
May 3, 2023 at 11:41 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 4, 2023 at 10:49 AM
