Tool size for timing chain bolt
2012 CHEVROLET CRUZE
75,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
BWHUOT63
  • 15 POSTS
For the timing chain guide bolt part # 90531117, what type socket and size do I need?
Oct 6, 2020 at 4:02 AM
Good morning,
I attached the set of sockets you will need. They do not specify the exact size of the socket but they are torx sockets. The hole set is $10.00.
I attached a picture of the bolt. Is this what you are referring to?
https://www.harborfreight.com/38-in-drive-star-bit-socket-set-6-pc-67886.html?_br_psugg_q=torx+socket
Oct 6, 2020 at 5:12 AM
BWHUOT63
  • 15 POSTS
I believe so, the bolts are located in the valve cover.
Oct 6, 2020 at 7:11 AM
BWHUOT63
  • 15 POSTS
Video. https://youtu.be/p9S6qm2Gc6Y
Oct 6, 2020 at 7:18 AM
In the valve cover? Please explain.
Can you upload a picture for me to view?
Oct 6, 2020 at 7:22 AM
Sorry, I just got the YouTube video of you finding the issue.
Good find. It is never common for the plugs to be loose unless they were never torqued when installed.
Oct 6, 2020 at 3:20 PM
