It is difficult to test the TIPM, but can I ask if the #2 fuse has power? If not the TIPM is bad. If so, I would replace the TCM. Here is the location. You might want to try unplugging and check the electrical connection for corrosion which can cause the problem. Then plug it in again to see if you had a bad connection. Check out the images (below). Let us know what you find.
Jul 31, 2024 at 11:44 AM
