Code 0300, multiple misfires?
2011 NISSAN TITAN
136,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ABUSTA33
  • 4 POSTS
Continue to get a service engine soon light and code of 0300, multiple misfires. I replaced plugs with NGK iridium, did an ignition test on all coils which all fire. I can hear the fuel injectors clicking with no abnormal sounds. I cleaned the MAF sensor and had an engine and fuel clean with BG product kit by a mechanic. Also, dry compression on cylinders is about 180-195. Clear engine light and once I drive and accelerate around 45 MPH after about 10 minutes of driving the code 300 comes back.
Jul 30, 2022 at 10:25 AM
Have you checked to make sure there are no engine vacuum leaks? Also, has fuel pressure been checked? I realize the injectors are working but the fuel pressure could be weak, or the regulator could be allowing pressure to be high.
By chance, do you have a live data scan tool? If you do, could you let me know what the short-term fuel trims are? Also, I need you to check the engine coolant temperature sensor signal to confirm it seems to be correct. For example, does it tell the computer the engine is 90 degrees when it is actually at operating temperature?
If you haven't checked for vacuum leaks, here is a link that explains how to do it:
Jul 30, 2022 at 11:12 PM
ABUSTA33
  • 4 POSTS
Joe,
Thanks, but I do not have a live data scanner. I hooked up a vacuum gauge tester and saw the truck idle at 11 which I read indicates a vacuum leak or possible valve issue. I checked all my hoses and don't see any visible cracks or breaks. I may have a gasket fail on my manifold, but I don't have a smoke tester. Current did a check on codes and it down to a 0303-cylinder three misfire. Thanks for your response.
Jul 31, 2022 at 2:52 PM
If it is one specific cylinder, we can do some tests. First, the vacuum reading is lower than expected. Did you try using carb cleaner to locate a leak?
Next, try this. I need you to switch the cylinder 3 coil pack to a different cylinder. While you have it out, check the spark plug condition in cylinder 3.
If the plug looks okay, reinstall the coils in the different places and let's see if the misfire moves to a different cylinder.
Let me know what you find.
Jul 31, 2022 at 9:45 PM
ABUSTA33
  • 4 POSTS
Joe,
Thank you for the advice but after trying to find a leak I could not. I took it into a shop, and everything looks great with the exception of some carbon build up on my pistons and valves. I was provided pictures and saw that the buildup was not allowing my valves to seat properly and allowing some oil in which starts to foul my plugs. Valve is also an indicator of my vacuum gauge test reading 11 in which I read.
Al
Aug 5, 2022 at 4:59 PM
Were they able to decarbon the valves/pistons? If so, is everything working properly now?
Aug 5, 2022 at 5:59 PM
ABUSTA33
  • 4 POSTS
Joe,
As of today, they were working on that and should be ready for pick up tomorrow after they finish cleaning and test it. I will post and let you know.
Aug 5, 2022 at 6:07 PM
Sounds good. I will watch for your reply.
Aug 5, 2022 at 6:51 PM
