Tire sizes
2011 FORD FUSION
85,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
FLIPPA334
  • 42 POSTS
What is the difference between a 225/50/17 and a 225/50R/17?
Nov 30, 2018 at 5:14 AM
Good morning again,
The R designates radial. They do not or should not make non radial tires anymore.
Use the 225/50R/17.
Are you replacing with new or do you have an issue?
Nov 30, 2018 at 5:23 AM
FLIPPA334
  • 42 POSTS
Replacing and what is the rim diameter so I can replace them also?
Nov 30, 2018 at 5:28 AM
The 225 is the width of the tire that hits the road way.
The 50 is the aspect ratio or the distance from the rim to the top of the tire.
17 is the rim diameter.
Nov 30, 2018 at 5:51 AM
FLIPPA334
  • 42 POSTS
I meant the width and depth. Sorry about that.
Nov 30, 2018 at 6:05 AM
That is something you need to measure. I cannot see it from here.
With the tire removed, you measure the rim width with a measuring tape. It could be anywhere from five inches to nine inches.
Nov 30, 2018 at 6:12 AM
