Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Fusion
Tires
Size
Tire sizes
2011 FORD FUSION
85,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
FLIPPA334
MEMBER
FOLLOW
What is the difference between a 225/50/17 and a 225/50R/17?
Nov 30, 2018 at 5:14 AM
CERTIFIED EXPERT
Good morning again,
The R designates radial. They do not or should not make non radial tires anymore.
Use the 225/50R/17.
Are you replacing with new or do you have an issue?
Nov 30, 2018 at 5:23 AM
FLIPPA334
MEMBER
Replacing and what is the rim diameter so I can replace them also?
Nov 30, 2018 at 5:28 AM
CERTIFIED EXPERT
The 225 is the width of the tire that hits the road way.
The 50 is the aspect ratio or the distance from the rim to the top of the tire.
17 is the rim diameter.
Nov 30, 2018 at 5:51 AM
FLIPPA334
MEMBER
I meant the width and depth. Sorry about that.
Nov 30, 2018 at 6:05 AM
CERTIFIED EXPERT
That is something you need to measure. I cannot see it from here.
With the tire removed, you measure the rim width with a measuring tape. It could be anywhere from five inches to nine inches.
Nov 30, 2018 at 6:12 AM
