Tires
2012 SUBARU IMPREZA
44,000 MILES • 2.0L • 4 CYL • AWD • MANUAL
OFRRIPPER
Four identical winter tires, tread and depth.. 3 195 55 15 but 1 is a 195 65 15 safe to run for a few months on a symmetrical all wheel drive?
Nov 27, 2016 at 5:01 PM
CARADIODOC
  • 34,306 POSTS
I am not as familiar with your All-Wheel-Drive system as you are, but I can offer some guidance. You need to look at the outer circumference of all four tires. Older Jeeps and Chevrolet Astrovans used full-time all-wheel-drive that constantly locked the front and rear driveshafts together. You would even run into problems if you bought two new tires one day, then the other two identical brand, model, and size a month later from the same store. Very slight production tolerance differences put a constant stress on the transfer cases and caused many of them to fail. Many articles have been written about this problem and who pays for the damage.
If your vehicle uses any type of viscous coupling that allows the two drive shafts to turn at slightly different speeds, mismatched tire size is not as critical. Of course if you can shift to two-wheel-drive for normal driving, this is even less of an issue.
Nov 27, 2016 at 6:06 PM
CJ MEDEVAC
  • 11,004 POSTS
Not a good idea.
Even though this would not be good, a FWD vehicle pulling two different sized tires in the rear, I could see that the car would not really care what was back there as they would just be free-wheeling.
In your question, one tire is a different size and your vehicle is AWD, meaning it drives from the front and the rear.
It has two differentials, which mainly compensate for turning. Whereas one wheel travels further than the other during the turn. The differential allows the turn to work smoothly (instead of dragging the wheel traveling the further-est or it 'hopping' around.)
What would really be happening in your scenario is the vehicle would constantly 'think' that that axle was in a constant turn, like never ending! One wheel travels further (or lesser) than the other on one axle rotation
Maybe the differential might compensate for that axle, But now that axle ratio is different from the other axle. The axles cannot have different ratios, as they would fight each other constantly and bind against each other.
Now lets throw in a computer and computerized drive train. Surely, it too, would get confused and try to compensate for the glitching.
I would say for sure that mechanical things might suffer, and maybe your safety too.
Sorry, I would give the idea a Thumbs Down!
The Medic
Nov 27, 2016 at 6:16 PM
