There is no reset button but here are the instructions on how to reset the system
Reset Procedure
Once the vehicle has remained stationary for more than 20 minutes, drive the vehicle for a minimum of 10 minutes while maintaining a continuous speed above 15 MPH (24 km/h).
If the warning light stays on you probably have a tire pressure sensor that needs to be replaced, you can find out which one by doing a CAN scan. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Amazon CAN scanner link for about $35.00.
https://amzn.to/3R9lJ60
Oct 30, 2022 at 12:59 PM
