The power steering pump makes a humming/whining noise when the engine is running. Do you know if this needs to be replaced or just bled? Additionally, the dash says tire pressure monitoring system. What could be the problem with that? Also, the car is not inspected yet. It needs an inspection done in NJ. I hooked up my scanning tool to the vehicle and found what I think are some potential issues. Can anyone tell me anything about the data below and potential fixes involved?
2006 Chevrolet Impala C = 5.3
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon dis
Htd Catalyst n/a
Evap System Mon dis
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon dis
Oxygen Sens Htr dis
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0513 ECM
Incorrect Immobilizer Key
HISTORY
MIL NOT REQUESTED
Since last key cycle NOT RUN
Since DTCs erased PASS/FAIL
C0899 ABS
Device 1 Voltage Low
HISTORY
MIL NOT REQUESTED
Since last key cycle PASS
Record Data
FRAME: 0 TM: 0.0
ABS LOAD(%) 20.0
ABS TPS B(%) 22.4
ABSLT TPS(%) 23.1
ACC POS D(%) 9.4
ACC POS E(%) 19.2
BARO PRS("HG) 30.4
CALC LOAD(%) 20.4
CAT TEMP11(°F) 752
CLR DIST(mi) 2
CLR DIST(mi) 2
CLR TRPS 3
CLR TRPS 4
CMD EQ RAT 0.999
COOLANT(°F) 203
ENG RUN(m:s) 00:28
ENG SPEED(RPM) 601
EVAP PURGE(%) 0.0
EVAP VP(H2O) -0.092
FUEL LEVEL(%) 24.3
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
IAT(°F) 100
IGN ADV(°) 11.0
LT FTRM1(%) 0.8
MAF(LB/M) 0.84
MAP("HG) 10.6
MIL DIST(mi) 0
MIL DIST(mi) 0
MIL STATUS Off
MIL STATUS Off
O2S11(V) 0.180
O2S12(V) 0.845
OBD2 STAT EU/CA
OUT TEMP(°F) 82
REL TPS(%) 12.6
ST FTRM11(%) -3.9
ST FTRM1(%) -3.9
THROT CMD(%) 16.5
VEH SPEED(MPH) 0
VPWR(V) 13.673
VPWR(V) 13.524
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon dis
Htd Catalyst n/a
Evap System Mon dis
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon dis
Oxygen Sens Htr dis
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0513 ECM
HISTORY
MIL NOT REQUESTED
C0899 ABS
HISTORY
MIL NOT REQUESTED
Record Data
FRAME: 0 TM: 0.0
ABS LOAD(%) 20.0
ABS TPS B(%) 22.4
ABSLT TPS(%) 23.1
ACC POS D(%) 9.4
ACC POS E(%) 19.2
BARO PRS("HG) 30.4
CALC LOAD(%) 20.4
CAT TEMP11(°F) 752
CLR DIST(mi) 2
CLR DIST(mi) 2
CLR TRPS 3
CLR TRPS 4
CMD EQ RAT 0.999
COOLANT(°F) 203
ENG RUN(m:s) 00:28
ENG SPEED(RPM) 601
EVAP PURGE(%) 0.0
EVAP VP(H2O) -0.092
FUEL LEVEL(%) 24.3
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
IAT(°F) 100
IGN ADV(°) 11.0
LT FTRM1(%) 0.8
MAF(LB/M) 0.84
MAP("HG) 10.6
MIL DIST(mi) 0
MIL DIST(mi) 0
MIL STATUS Off
MIL STATUS Off
O2S11(V) 0.180
O2S12(V) 0.845
OBD2 STAT EU/CA
OUT TEMP(°F) 82
REL TPS(%) 12.6
ST FTRM11(%) -3.9
ST FTRM1(%) -3.9
THROT CMD(%) 16.5
VEH SPEED(MPH) 0
VPWR(V) 13.673
VPWR(V) 13.524
Sep 10, 2019 at 7:00 PM
