tire whine noise
2008 CHEVROLET TRAILBLAZER
120,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
BUZZ GARRETT
  • 5 POSTS
Tire noise like big truck tire noise but under drivers feet. I just recently started with tires about six months old. Engine running: parked, no noise; no gear noise when changing; driving to 35 mph I can hear-tire like noise. Shift to neutral and coast to stop, no change in noise except with the slowing. When Driving shift through all gears there is no change, 4wd shift on and off no change.
fluid in engine, transmission, etc. all good.
Thanks for any ideas!
Jun 7, 2016 at 7:45 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked the tires themselves? Also will the noise get louder or quieter when turning lane changes etc? You could have a bad wheel bearing.
Jun 7, 2016 at 7:55 AM
BUZZ GARRETT
  • 5 POSTS
The tires appear okay. I ran my hand over all four and did not feel any high spots, or saw tooth. I will try turning the wheel at speed. Thanks for any ideas!
Jun 8, 2016 at 7:07 AM
SATURNTECH9
  • 30,869 POSTS
If you have a jack and jack stands I can tell you how to check the wheel bearings.
Jun 8, 2016 at 12:30 PM
BUZZ GARRETT
  • 5 POSTS
I do have garage jack and jack stands. Thank you
Jun 8, 2016 at 3:13 PM
SATURNTECH9
  • 30,869 POSTS
Put it up on jack stands in 2wd with the tires off the ground .Put one hand on the coil spring and use the other hand to spin the tire as fast as you can. Compare both sides to each other.If the bearing is bad you can usually feel it in the coil spring.
Jun 8, 2016 at 10:34 PM
BUZZ GARRETT
  • 5 POSTS
Excellent advice; and it worked. That coupled with the previous advice from someone about riding in opposite circles at the local Walmart identified the problem. Fixed it yesterday. Thank you!
Jun 13, 2016 at 4:30 AM
Good to hear, please use 2Carpros anytime we are here to help.
Jun 13, 2016 at 8:08 AM
SATURNTECH9
  • 30,869 POSTS
So was it a bad wheel bearing?
Jun 13, 2016 at 8:28 AM
BUZZ GARRETT
  • 5 POSTS
Yes! And thanks again. All fixed now.
Jun 13, 2016 at 9:06 AM
Here is a video on the repair for a similar vehicle
https://youtu.be/ZgiPRG6jffc
Jun 13, 2016 at 9:11 AM
SATURNTECH9
  • 30,869 POSTS
Yeah I have been using that spining the wheel by hand and feeling the bad bearing in the coil spring for years.
Jun 13, 2016 at 12:31 PM
