I keep trying to fill my flat tire. The problem is that the PSI as soon as I turn on compressor shoots up to 100+ PSI and shuts off compressor, as I put it up that high just to try to fill it at all, then Fastly falls back down. The tire is flat. I have it jacked up, so pressure isn't on it. I have 2 different compressors and the same thing is happening to both. Therefore, I can't fill the tire. I have already put in a new valve core.
Any thoughts?
Thank you.
Any thoughts?
Thank you.
Nov 13, 2023 at 11:27 AM
