I attached the wiring schematic for the circuit below. It appears that fuse M15 is the supplier of power in this case.
Fuse M15 is located in the totally integrated power module (TIPM). These modules have a history of failure due to the connectors being small and can crack or corrode. Also, it appears to be in connector 5, pin 4. It will be a pink wire with a light green tracer.
The first two pictures below are the schematic. I had to cut it in half to make it readable, but I did overlap them so you can follow from one to the next.
The last four pics are specific to connector 5.
Let us know if this helps or if you have other questions.
See pics below.
Jul 25, 2025 at 9:34 PM
