While adding oil, I think a tiny bit of tin foil from the seal may have gotten into the oil filler funnel that runs down and is attached to the outside of the right cylinder head and then goes down and make a little right angle turn and is attached by a plate. Looks like it enters into the cylinder head, even with or a little below the valve train.
Was wondering is it worth taking the funnel and plate off the cylinder head to look for it or does it go into a straight passageway down into the oil pan where it will be trapped assuming there is a filter before the pump?
My concern is that it will block an oil passageway or something else I am not aware of.
Thanks for the help.
Aug 12, 2018 at 4:19 PM
