Camshaft timing problem?
2002 FORD LASER
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
GALWYNN
  • 4 POSTS
Need help doing with timing on my vehicle listed above.
Jan 18, 2025 at 3:14 PM
The ignition timing is not adjustable, is that what you meant?
Base Timing .................... 10 degrees ± 2 degrees BTDC (Not Adjustable)
Let us know if you need anything else.
Jan 19, 2025 at 10:21 AM
GALWYNN
  • 4 POSTS
sorry it's the cam timing i can't quite get it right or find anything on how to.
Jan 19, 2025 at 1:37 PM
Gotcha, here is the timing belts marks for the timing belt replacement procedure. Check out the images (below). Let us know if you need anything else.
Jan 20, 2025 at 10:12 AM
GALWYNN
  • 4 POSTS
yeah that's what i need but for the 1.6 16 valve DOHC. It's a 2002 Ford laser LXI.
Jan 20, 2025 at 7:49 PM
GALWYNN
  • 4 POSTS
Has got letters for intake and exhaust on both cam pulleys but not sure where they're meant to line up.
Jan 20, 2025 at 7:54 PM
Okay, this one is a little different, you will need a couple special tools that line up the camshaft and crankshaft. Here are the instructions. Check out the images (below). Let us know if you need anything else.
Jan 21, 2025 at 10:41 AM
