I replaced my distributor because the old one failed. Now I'm having great issue with trying to get it timed, I went and bought a timing light, and I followed the instructions in the manual. While in neutral I place first cylinder at top dead center and continue to hand crank engine till the mark on the dampener is liked up with the zero, I unplug the tan and black wire under my dash and set up the timing light. I start the truck while still in neutral and check the mark with the light and rotate distributor accordingly so mark lines back up with zero, then I put truck into park and shut it off and plug the wire back in, pull the two ECM fuses from the fuse box located under the hood and wait 30 seconds before installing them to reset the fault code. I then tighten down the distributor and I start my truck again and check with mark one last time with the light just to find the mark to be way out to lunch. I've tried the same procedure while in park, I've tried unplugging the wire while the truck is running, in neutral and in park. It doesn't seem to matter which way I do it the outcome is the same, the mark is other nowhere to be seen or way before the little plate with the numbers or way after the plate. What am I doing wrong here? I followed the procedure of how to properly install the distributor and made sure they were exactly the same before installing, so I don't get it... Also when I installed the distributor the first time and did the timing I never checked it after I started it again to see if the mark was still correct ( didn't think I had too) the only reason why I checked was because the truck was shooting out codes 35 & 42 and started running rough and had no power while accelerating.. I changed the fuel filter, the fuel pump just recently and replaced the fuel injectors and pretty much all the sensors but crank sensor and o2 sensor. If you can tell me what I'm doing wrong, it would be appreciated. Thanks
I have a 350 v8 5.7l TBI engine in my 95 Chevy 1500.
Mar 30, 2024 at 7:15 PM
