Okay, so I had oil in my spark plug cylinders. I had to change out the valve cover gasket kit. When I reinstalled the rocker arm assembly I think that I may have not checked to see if I moved the crank, but it doesn't run and also does not want to start at all. Any way I can fix the timing would be very appreciated. Thought about just getting a timing gun but I think the cam is just not at the right position. any help would really be a great Christmas present to me thanks. Okay, so I just stripped everything back down so rocker arm assembly is off so cam shaft is showing. How do I know the crank and cam are at right position to reinstall everything and set timing from distributor?
Dec 24, 2018 at 4:18 AM
