Hi All I have replaced the bushing under the oil pump drive shaft and the shaft. I am having trouble timing the oil pump drive gear to the crankshaft. Where should the crankshaft be positioned and where should the slot for the distributor drive lined up? I have replaced the distributor before so I am a-where of the syncing process.
May 27, 2013 at 8:00 PM
