Timing cover removal?
1988 CHEVROLET CAVALIER
153,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 75 POSTS
What size torx head are the 2 studs in the bottom of the timing cover?
Nov 10, 2024 at 4:31 PM
With the 2.0L engine, the two studs at the bottom of the timing cover typically require a T40 Torx bit for removal.
Here is how to remove the timing cover correctly:
This video will show you how to remove the balancer:
https://youtu.be/WITN7Q8SX1U?si=1yvm-4mihmRsCSRH
Nov 10, 2024 at 6:01 PM
TJMOWBRAY
  • 75 POSTS
Thanks, I just had to remove oil pan.
Nov 11, 2024 at 12:55 AM
You are welcome, please use 2CarPros anytime we are here to help.
Nov 12, 2024 at 10:40 AM
