Good morning,
Why are you replacing the tensioner? Is it making noise?
Usually you replace the chain at the same time.
Camshaft Timing Chain, Sprockets, and Tensioner Replacement
1. Disconnect the negative battery cable.
2. Remove the No. 1 cylinder spark plug. Refer to Spark Plug Replacement See: Spark Plug > Procedures.
3. Rotate the crankshaft in the engine rotational direction clockwise, until the No. 1 piston is at top dead center (TDC) on the compression stroke.
4. Raise and support the vehicle.
5. Remove the engine front cover. Refer to Engine Front Cover Replacement See: Timing Cover > Procedures.
6. Lower the vehicle.
7. Remove the camshaft cover. Refer to Camshaft Cover Replacement See: Valve Cover > Procedures.
Important: The timing chain tensioner must be removed to unload chain tension before the timing chain is removed. If not removed, the timing chain will become cocked and it will be difficult to remove.
8. Remove the timing chain tensioner.
9. Remove the upper timing chain guide.
10. Use a 24 mm wrench to hold the camshafts from turning.
11. Remove the exhaust camshaft sprocket bolt and discard.
12. Remove the exhaust camshaft sprocket.
13. Remove the timing chain tensioner guide.
Apr 22, 2020 at 6:05 AM
